marksp618's avatar
marksp618
rbr50 v2
I have an RBR50v2 with one satellite the firmware is the latest available.  The router is connected to our HTC fiber to premises modem device via its ethernet port.  We pay for 300Mbps speed up and d...
  • marksp618's avatar
    marksp618
    Sep 14, 2022
    Thank you for your help. It looks as if it is the switch that went bad ( thankfully not an Orbi) a direct wire connection without the switch (used house wire) to the satellite and everything is working again. Getting 295 Mbps wifi again.
    I will have to see if I can relocate the Orbi router out of a closet where the builder installed our wire closet. Hopefully then the backhaul connection can be wifi. For now. I'm happy to get the wifi up and running!!
    Thanks again for your help.
    Mark
