AwesomeQA
Jul 18, 2020Apprentice
RBR50 with 7 Sats High CPU utilization
Hello, I have 5 Sats currently connected to RBR50 ethernet backhaul and 2 sats connected as wireless backhaul with the latest firmware 2.5.1.32. I noticed that RBR50 CPU runs between 80% to 90% wit...
- Jul 26, 2020
Now RBR50 CPU runs from 6% to 30% with FW V2.3.5.30 with 7 Sats with no issues.
It appears to me that FW 2.5.x is too buggy and needs more work.
AwesomeQA
Jul 26, 2020Apprentice
I found that Netgear removed FW version 2.5.1.32.
AwesomeQA
- FURRYe38Jul 26, 2020Guru - Experienced User
I presume maybe. Something to contact NG support about. However again, you may run into problems having more than officially supported RBS which NG would not try to fix for you.
Current v16 FW is working for me and generally most others. Most stable version IMO though I don't have 7 RBS connected.
Good luck.
- mith_itJul 26, 2020Luminary
Check out this post: http://www.snbforums.com/threads/custom-firmware-build-for-orbi-rbk50-rbk53-rbr50-rbs50-v-9-2-5-1-33sf-hw.65137/post-604740
it looks like Voxel has recompiled the inetd service and released a new version if you want to try it.
Heres the change log:
