bnbyrnes
Feb 03, 2021Guide
RBR50v2 Firmware Upgrade 2.7.2.104 Lost Parental Controls
I read that Circle is going away and I found this link to install Netgear Smart Parental Controls (https://kb.netgear.com/000062852/How-do-I-upgrade-from-Circle-to-NETGEAR-Smart-Parental-Controls#To%...
vajim
Feb 24, 2021Master
FURRYe38 wrote:You can contact a forum moderator and let them know about what your seeing if you can't get this working.
he just did
bnbyrnes
Mar 02, 2021Guide
Magically 3 days ago the Orbi software on my phone asked me if I wanted to install Netgear Parental Controls! So maybe the Orbi software just needed an upgrade?
Installed and testing.. so far so good. Kids are complaining that some things are not working like Discord voice so I will have to do some investigating and also they are complaining about speeds. I don't see any problems but they move a whole lot faster than I do.
Anyway glad they finally caught up.
- FURRYe38Mar 02, 2021Guru - Experienced User
Gald it finally got thru to you. Do you know if your Orbi app was updated recently?
Did the Orbi app have you install a different app like Circle or is this with in the Orbi app?
Please mark your thread as solved so others will know.
bnbyrnes wrote:Magically 3 days ago the Orbi software on my phone asked me if I wanted to install Netgear Parental Controls! So maybe the Orbi software just needed an upgrade?
