JohnVL62's avatar
JohnVL62
RBS 50 Router connected to Giga Switch GS108
We have connected a GS 108 giga switch directly into the wired port of our Orbi router. If I hard connect my computer into the router, I can get internet access.  Unfortunately, when I connect my com...
  • FURRYe38's avatar
    Ah yes. That can happen. Glad it was a easy fix.
    Please mark your thread as solved so others will know.
    Enjoy. :smileywink:
    JohnVL62 wrote:
    Thank you for all your useful suggestions and advise.  Turns out someone had inserted a second input feed into the switch which was causing the switch not to work.  Thank you again.  Problem has been resolved.
