tgarvey
Mar 18, 2019Tutor
RBS20 FW update
My package of an RBR40 and three RBS20s would not automatically detect and run the 2.3.0.28 FW updates when I logged in via my browser. I downloaded the two firmware files and first upgraded the RBR...
Mar 18, 2019Guru - Experienced User
Or you can manually install the FW files as well.
Good Luck.
tgarvey
Mar 18, 2019Tutor
As I said in my original post, that is what is not working. I've downloaded the RBS20 2.3.0.28 fw file sevral times, loaded and ran it, and each time I get an error message saying I'm using the incorrect file. And yes, I've made sure I'm running the RBS20 file, not the RBR40 file. FWIW, running the RBR40 file to update the router also retunred the same error message the first three times I ran it, until it worked.
- FURRYe38Mar 18, 2019Guru - Experienced User
Ok, hopefully the auto update will pick up the 3rd satellite.
Manual update should have work. Browser could have been a cause.
I use IE11, or FF for doing any FW updates.
Hope the last one updates correctly.
