tgarvey
Mar 18, 2019Tutor
RBS20 FW update
My package of an RBR40 and three RBS20s would not automatically detect and run the 2.3.0.28 FW updates when I logged in via my browser. I downloaded the two firmware files and first upgraded the RBR...
Chuck_M
Mar 18, 2019Mentor
In the firmware zip files are often two files... one that ends in .chk. That is not the firmware, it is the other file. What is the filename you are trying to upload to the firmware updater?
tgarvey
Mar 18, 2019Tutor
It's RBS20-V2.3.0.28.img
- plemansMar 19, 2019Guru - Experienced User
If you had issues uploading to the router maybe its a computer issue causing the problem. have you tried using a different computer to upload the image?
- tgarveyMar 19, 2019Tutor
The remaining RBS20 auto-updated overnight. I'm hopeful that the new FW resolves the 5.5 month long PITA experience with frequent satellite & internet disconnects. Fingers crossed.
Thank you all for your suggestions.
