AFD
Jan 29, 2021Luminary
RBS50 Connectivity problems and Issues
I have the same problem with almost the same symptons that reported in the following thread https://community.netgear.com/t5/Orbi/RBS50-connectivity-issues/m-p/1902652 Just starting , nothing...
AFD
Feb 05, 2021Luminary
Until now , more than 30 hous of work dedicated to this (........ adjetive will be filled when I finish) amazing and unpredictable piece of hardware .
After a lot of work a finally conect the satellite but , (It seems with Netgear you always have a but) no devices attached to it and also it figures in the administration app shows the satellite with the old firmware .
So I decided to start the process again with the satellite , but now is not possible to address 192.168.1.250 (???) - (I performed a factory reset again) .
Anyway , I decided to continue working with the main router and trying to work finally (Im going to dedicate and perform last efforts all weekend) .
Im in a moment of my life of not to losing time in small things (so searching for easy , no too much expensive pieces of hardware and working fine as Orbi used to be in the past)
If someone has some ideas about Drop connections issues are very welcome .
AFD
Thanks a lot to FURRYe38 for supporting , helping and giving his expetrise for trying to solve the problem
You are a Genious independently of the results .
Hoping solve the issue in the next days to continue belong to this community .
My compromise is to post all the testings done (like until today) and the final decision also . (it seems , that according other posts , Netgear's engineers and technical support are not too much worried about it)
