AFD
Jan 29, 2021Luminary
RBS50 Connectivity problems and Issues
I have the same problem with almost the same symptons that reported in the following thread https://community.netgear.com/t5/Orbi/RBS50-connectivity-issues/m-p/1902652 Just starting , nothing...
Feb 28, 2021Guru - Experienced User
Good Luck.
AFD
Mar 18, 2021Luminary
This has become a hobby - (no longer a problem, but it is a matter of self-love , pride , never surrender , to know what it's happening)
Did you think that the history of the RBK50 was over from my side?
The network, it is decided, will be changed by another Mesh system, meanwhile I decide the brand and model I am working with a low-cost router that covers the needs of 75% of the home (impressive performance)
Before archiving the Orbi, I told myself, why not leave everything to the latest firmware level (both Satellite and Router) ? , so the following actions were performed
65 - Factory reset was performed on the Router and the Satellite
66 - Firmware 2.7.2.104 was reinstalled on both
67 - Router and Satellite were connected by cable from a LAN port of the router to a Lan port of the Satellite - After several minutes the Blue Halo appeared on the satellite and both teams were left without any active LED -
68 - Surprise - The Wifi network was operating for more than 48 hours without problems or drops - few connected equipment to test and they do not drop.
69 - I decided again then to try to synchronize the satellite wirelessly to use it in wireless backhaul mode and the satellite does not synchronize (Magenta led) and the Wifi network begins to fall again.
70 - I turn off everything and connect everything by cable again and the Wifi network works perfectly - it is isolated without connected devices and the Satellite appears as a wired device not as a backhaul in the attached devices.
The incredible thing is that in this way the WiFi network remains stable and does not have drops, but as soon as the Ethernet cable is disconnected from the Satellite the WiFi network start to drops.
Any aditional ideas , comments , ? (as a comment from my side , I can't wire in my house and everything must be wireless)
- FURRYe38Mar 18, 2021Guru - Experienced User
Remove the RBS from the RBRs web page. Power cycle the RBS and RBR, then try to sync them both in the same room as the RBR. 10 feet or so away from the RBR. Let the RBS stand for 5-10 minutes after the sync to see if anything happens on the RBS...
AFD wrote:This has become a hobby - (no longer a problem, but it is a matter of self-love , pride , never surrender , to know what it's happening)
The network, it is decided, will be changed by another Mesh system, meanwhile I decide the brand and model I am working with a low-cost router that covers the needs of 75% of the home (impressive performance)Before archiving the Orbi, I told myself, why not leave everything to the latest firmware level (both Satellite and Router) ? , so the following actions were performed
70 - I turn off everything and connect everything by cable again and the Wifi network works perfectly - it is isolated without connected devices and the Satellite appears as a wired device not as a backhaul in the attached devices.The incredible thing is that in this way the WiFi network remains stable and does not have drops, but as soon as the Ethernet cable is disconnected from the Satellite the WiFi network start to drops.
- AFDMar 18, 2021Luminary
vajim wrote:FURRYe38 is actually trying to tell you your firmware is faulty
Could Be , but sincerely I'm lost because if you consider that failure started (without any change in the environment) with a very old fimware 2.3.5.30 (with the same issues like I have today with the 2.7.2.104) , sincerely for me is a SciFi .
So , gonna try what FURRYe38 proposed and let's see. Expectations are null .
FURRYe38 wrote:Remove the RBS from the RBRs web page. Power cycle the RBS and RBR, then try to sync them both in the same room as the RBR. 10 feet or so away from the RBR. Let the RBS stand for 5-10 minutes after the sync to see if anything happens on the RBS...
Tested as requested ending with Magenta Led in RBS and continuous White Blink Led in Router .(no sync possible) .See Picture above , this is the Only configuration where the WiFi is stable and not dropping .
I believe the action of syncing is failing because of the problem in the wifi .
You can try and downgrade the FW on the RBR and RBS and see if that does anything. Possible there maybe a hardware fault as well.
- AFDMar 22, 2021Luminary
FURRYe38 wrote:You can try and downgrade the FW on the RBR and RBS and see if that does anything. Possible there maybe a hardware fault as well.
71 - Done !! This is just a hobby for me to upgrade and downgrade de Orbi System .
Sorry to say but it doesn't work . Downgrading firmware to 2.7.2.102 - Behaviour is the same - Wired OK - Satellite connected to router and Wifi Stable , as soon as you unplug the ethernet - Wifi drops - Satllite refused to sync wirelessly . :-(
New equipment already bought today in USA - Waiting for delivery and shipping time to my country .
Despite of the decision made , I'm going to continue testing (depending on availability) your ideas and proposals for testing are always very welcome . May be if someone can share this information with Netgear Technical Support L2 could be useful , but sincerely I don't have any positive expectations about it .
Many thanks all the comunity , for helping and supporting (In case I have some news regarding testing activities I will let you know , just to help others with similar issues) .
- FURRYe38Mar 22, 2021Guru - Experienced User
Seems like a hardware failure since this has been happening for a while across different versions. Sorry we couldn't get it working for you.
FURRYe38 wrote:Seems like a hardware failure since this has been happening for a while across different versions. Sorry we couldn't get it working for you.
Please , no apologies needed . Apologies should be come from Netgear , I didn't claim anything to them , no reimbursement , no RMA , no new products , just a simple explanation of what is happening , but nothing .
It's not a surprise , if you search in this and other forums like reddit , or social networks , they are plenty of users claiming with no answering and much worst than me , because they bought one or two monthes ago and in my case I could enjoy Orbi for almost 3 years.
I've tested also Voxel Firmware with the same results Wifi Drops , so is very difficult to accept but perhaps it is a Hardware problem . (as always said HW should never failed , but SW can't never , if you've tested it in the proper way and with the right metodology) .
And the most important topic in the decision making process is the user experience , as you can imagine I can't talk this as a satisfactory with the exception of this community support .
Stupid me , I didn't realize , when I bought , the expiration date for technical support in 90 days , because decision in this moment could be different .
Now Technical Support was the number one topic in the decision making process . Also because I tested it with another equipment and it is almost closer to perfect . (perhaps harware won't be the best , but I least you have someone listening and helping you on the other side of the planet , with no extra costs)
This community is one of the best I can see , but it's not an excuse for the NG Company to refuse support to end users and rest in the community to give us solutions .
This is my opinion - Sorry for the bla bla bla ,,, but I'm very angry with the NG Technical support behavior . Anyway , there are much more important things than a Mesh system that you can replace .
Hardware?
across different versions?
HI vajim
If you another test to be done I will be ready to perform it -
But if I tested a lot of firmwares , and considering also Voxel ones , and if the problem started without any change in the environment , I believe we have two alternatives .
1 - Hardware failure
2 - Hardware expiration date (many articles talk about it , I don't believe it , but ....) which could be software .
Anyway as mentioned above , many thanks for supporting and helping .
- vajimMar 22, 2021Master
AFD wrote:
Hardware?
HI vajim
what are you asking?
vajim wrote:
AFD wrote:
Hardware?
HI vajim
Nothing . Just post the last activity and as fars as I know you posted a question . (Anyway , I don't have any answer yet and perhaps I never know) .
- AFDMar 23, 2021Luminary
72 - Is too Funny , in the meantime I'm playing wiith the Orbi adding more and more devices with no wifi disconnection (running ok with the wired satellite) but (you always have a but with Netgear Orbi) I'm experimenting the famous DNS problems -
Some of the devices refuse to connect (specially a Notebook) and voilaa ,
I don't have DST enabled , I don't have the traffic metter enabled , and the only way to solve the problem was to change the DNS assignment on the client side ... (it's beatiful , isn't it) .
This is not a question , this is a fact about the past and actual state of the art of Orbi firmware .
- AFDMay 16, 2021LuminaryEnd of story .
Orbi system repacked and archived .
New mesh system up & running without problems until now since last week .
Hope to continue in this way .
Too sad how to finished without a single NG explanation .
Anyway there are more important things than a WiFi system which can always be replaced .
Good luck and thanks for helping to all the community . - AFDJun 16, 2021Luminary
Surprise : Amazon / Fakespot (at least for me)
https://www.fakespot.com/product/netgear-orbi-high-performance-ac3000-tri-band-wifi-system-rbk50
Give a look to reviews , analysis and comments .
