AFD
Jan 29, 2021Luminary
RBS50 Connectivity problems and Issues
I have the same problem with almost the same symptons that reported in the following thread https://community.netgear.com/t5/Orbi/RBS50-connectivity-issues/m-p/1902652 Just starting , nothing...
Mar 18, 2021Guru - Experienced User
You can try and downgrade the FW on the RBR and RBS and see if that does anything. Possible there maybe a hardware fault as well.
AFD
Mar 22, 2021Luminary
FURRYe38 wrote:You can try and downgrade the FW on the RBR and RBS and see if that does anything. Possible there maybe a hardware fault as well.
71 - Done !! This is just a hobby for me to upgrade and downgrade de Orbi System .
Sorry to say but it doesn't work . Downgrading firmware to 2.7.2.102 - Behaviour is the same - Wired OK - Satellite connected to router and Wifi Stable , as soon as you unplug the ethernet - Wifi drops - Satllite refused to sync wirelessly . :-(
New equipment already bought today in USA - Waiting for delivery and shipping time to my country .
Despite of the decision made , I'm going to continue testing (depending on availability) your ideas and proposals for testing are always very welcome . May be if someone can share this information with Netgear Technical Support L2 could be useful , but sincerely I don't have any positive expectations about it .
Many thanks all the comunity , for helping and supporting (In case I have some news regarding testing activities I will let you know , just to help others with similar issues) .
- FURRYe38Mar 22, 2021Guru - Experienced User
Seems like a hardware failure since this has been happening for a while across different versions. Sorry we couldn't get it working for you.
- AFDMar 22, 2021Luminary
FURRYe38 wrote:Seems like a hardware failure since this has been happening for a while across different versions. Sorry we couldn't get it working for you.
Please , no apologies needed . Apologies should be come from Netgear , I didn't claim anything to them , no reimbursement , no RMA , no new products , just a simple explanation of what is happening , but nothing .
It's not a surprise , if you search in this and other forums like reddit , or social networks , they are plenty of users claiming with no answering and much worst than me , because they bought one or two monthes ago and in my case I could enjoy Orbi for almost 3 years.
I've tested also Voxel Firmware with the same results Wifi Drops , so is very difficult to accept but perhaps it is a Hardware problem . (as always said HW should never failed , but SW can't never , if you've tested it in the proper way and with the right metodology) .
And the most important topic in the decision making process is the user experience , as you can imagine I can't talk this as a satisfactory with the exception of this community support .
Stupid me , I didn't realize , when I bought , the expiration date for technical support in 90 days , because decision in this moment could be different .
Now Technical Support was the number one topic in the decision making process . Also because I tested it with another equipment and it is almost closer to perfect . (perhaps harware won't be the best , but I least you have someone listening and helping you on the other side of the planet , with no extra costs)
This community is one of the best I can see , but it's not an excuse for the NG Company to refuse support to end users and rest in the community to give us solutions .
This is my opinion - Sorry for the bla bla bla ,,, but I'm very angry with the NG Technical support behavior . Anyway , there are much more important things than a Mesh system that you can replace .
Hardware?
across different versions?
HI vajim
If you another test to be done I will be ready to perform it -
But if I tested a lot of firmwares , and considering also Voxel ones , and if the problem started without any change in the environment , I believe we have two alternatives .
1 - Hardware failure
2 - Hardware expiration date (many articles talk about it , I don't believe it , but ....) which could be software .
Anyway as mentioned above , many thanks for supporting and helping .
- vajimMar 22, 2021Master
AFD wrote:
Hardware?
HI vajim
what are you asking?
vajim wrote:
AFD wrote:
Hardware?
HI vajim
Nothing . Just post the last activity and as fars as I know you posted a question . (Anyway , I don't have any answer yet and perhaps I never know) .
- AFDMar 23, 2021Luminary
72 - Is too Funny , in the meantime I'm playing wiith the Orbi adding more and more devices with no wifi disconnection (running ok with the wired satellite) but (you always have a but with Netgear Orbi) I'm experimenting the famous DNS problems -
Some of the devices refuse to connect (specially a Notebook) and voilaa ,
I don't have DST enabled , I don't have the traffic metter enabled , and the only way to solve the problem was to change the DNS assignment on the client side ... (it's beatiful , isn't it) .
This is not a question , this is a fact about the past and actual state of the art of Orbi firmware .
- AFDMay 16, 2021LuminaryEnd of story .
Orbi system repacked and archived .
New mesh system up & running without problems until now since last week .
Hope to continue in this way .
Too sad how to finished without a single NG explanation .
Anyway there are more important things than a WiFi system which can always be replaced .
Good luck and thanks for helping to all the community . - AFDJun 16, 2021Luminary
Surprise : Amazon / Fakespot (at least for me)
https://www.fakespot.com/product/netgear-orbi-high-performance-ac3000-tri-band-wifi-system-rbk50
Give a look to reviews , analysis and comments .
