LetsGoDevils
May 07, 2018Tutor
RBW30 needs to be unplugged frequently
Good afternoon,
I purchased an RBK33 system a few weeks back and after a strenuous installation using the app, I tried installation via orbilogin.net and think I got everything up and running p...
DarrenM
May 08, 2018Sr. NETGEAR Moderator
What firmware version is your main router on and the rbw30?
DarrenM
LetsGoDevils
May 08, 2018Tutor
Also under advanced wireless settings - Enable MU-MIMO is checked and the other 2 are NOT checked (enable implicit beamforming and fast roaming). Should I check those?
- DarrenMMay 08, 2018Sr. NETGEAR Moderator
I want to get you in contact with support I sent you a PM
DarrenM
- LetsGoDevilsMay 21, 2018TutorHello - I PM'ed you back immediately and still haven't heard back from support. And now I've lost the ability to return this item and am stuck with it. And to add, NOW I learn that this network acts up with my Google home and chromecast audios. I wish I could return this over priced junk.
- DarrenMMay 22, 2018Sr. NETGEAR Moderator
Hello LetsGoDevils
I am very sorry that you have not been contacted I escalated your info again to support they should be reaching out to you.DarrenM
