Berkie's avatar
Berkie
rename SSID / network name
Hello everybody, to avoid extra work with installing a new set of ORBI's. Can I rename the ORBI SSID to my current network name? This because of home automation and heating and other appliances att...
  • aaz's avatar
    Jan 04, 2018
    Yes, you can rename the SSID just like on any router. Your post confuses me a bit though do you already have an orbi router and are installing another one - the orbi is only meant to function with a single Orbi router and some Orbi satellites with no other routers in the mix.
