gssng
Aug 13, 2024Aspirant
Re: Roborock Q Revo won't connect to Orbi wifi
furrye38, that also worked like a charm for me with an RBR50 with latest firmware. Thank you!
- Aug 14, 2024
I presume you had turned down the power on the RBR to 25%?
gssng
Aug 14, 2024Aspirant
You presume correctly! 😄
Aug 14, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
