Salvare
Oct 22, 2021Follower
Satelitte compatible with RBR50v2 available ?
Hello community, Can you please tell me what reference of satellite is compatible and available for RBR50v2 Orbi router ? Thanks in advance, S.
Oct 28, 2021Guru - Experienced User
I didn't refer to the EX as MESH sattellites. They are ONLY extenders so no they don't entegrate like actual RBS. They CAN work in cases were additional wifi is needed in a pinch and when RBS supplies are out of stock or can't be found. They don't need to integrate as well. Just provide additional wifi coverage for those situations. They work fine with Orbi systems.
wwlen1
Oct 29, 2021Guide
You can also get a RBR40 or RBR50(V1) router and convert them to the satellite versions.
There are a few threads on the Orbi Reddit that step you through it.
That's what I did. I found three RBR40 routers on Amazon for under $30 each with free shipping. Now I have a one satellite setup with a spare that can be used as with a satellite or router.
