SamGreen
Jun 29, 2020Aspirant
Secure Network
While connected to the Orbi network, every website I try to go to and even on my cell phone, tells me it cannot connect do to the network not being secure. Whenever I disconnect from the Orbi network...
CrimpOn
Aug 13, 2020Guru - Experienced User
NirmalM wrote:Also, do you recommend to change the default SSID / password combination to what I had for my previous Nighthawk Router, or is it easier to start a new SSID and reconfigure all my devices....
Every time I replace my WiFi router I give the new one exactly the same SSID/password as the one that is being replaced:
- This means that all of my devices will connect automatically without having to be reconfigured, and
- If I decide "this was a mistake. I want to go back", all I have to do is swap the old WiFi system back in and all devices will connect to it automatically.
NirmalM
Aug 13, 2020Aspirant
Thanks!
