FROMTHESWAMPWOO
Nov 09, 2019Aspirant
RE-SET UP ORBI
I HAVE CHANGED WIFI SINCE I HAD MY ORBI SET UP ORIGINALY. DO I HAVE TO CHANGE ANYTHING.....LIKE THE WIFI POASS WORD ?? IF SO HOW DO I DO THIS ? I DID NOT SET UP THE ORBI MYSELF SO I AM NOT SUR...
CrimpOn
Nov 09, 2019Guru - Experienced User
FROMTHESWAMPWOO wrote:I HAVE CHANGED WIFI SINCE I HAD MY ORBI SET UP ORIGINALY.
This doesn't give us much to work with. "Changed WiFi" could mean a lot of different things.
Are you able to access the Orbi WiFi by selecting the Orbi from a list of nearby WiFi networks and entering the password?
Are you seeking to make changes to the administrative interface, but do not know the administrative password?
A little more description of the problem would be helpful.
FROMTHESWAMPWOO
Nov 10, 2019Aspirant
OK MY WIFI SERVICE SENT ME A NEW WIFI ROUTER. CAN I JUST PLUG ORBI IN AND BE GOOD TO GO ? DO I HAVE TO PUT IN THE NEW ROUTER ( PASS WORD- THE BIG LONG ONE ON THE BACK OF ROUTER ) I AM SORRY I AM VERY IGNORANT ABOUT THIS STUFF BUT I DID NOT SET UP THE ORBI ORIGINALY SO I DO NOT HAVE A CLUE. I DID HAVE TO CHANGE THE INTERNET SERVICE NUMBER ON MY I PHONE DOES THAT HELP? WHAT I MEAN IS BEFOR IT WAS FRONTIER ??????? AND NOW I IT IS FRONTIER xxxxxx. IF I NEED TO DO THE SAME THING FOR MY ORBI HOW WOULD I GO ABOUT DOIN THAT?
THANKING YOU AGAIN,
ANN
- FURRYe38Nov 10, 2019Guru - Experienced User
If your service send you another router, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopPlease stop using caps. No need to yell.
