Jagan
Sep 13, 2017Aspirant
Slow speeds on WiFI
Hi, Got Orbi few days back very happy with the coverage even upgraded to the latest firmwarie which was release today. Using 100Mbps Fiber connection from my PC to Orbi thorugh LAN which...
DarrenM
Sep 14, 2017Sr. NETGEAR Moderator
Did you ever factory reset the unit since updating it?
DarrenM
Jagan
Sep 17, 2017Aspirant
Just wanted post the update regarding the issue now my replacment Orbi has arrived
Tested it with default firmware speed was more are like same 20-40mbps
So updated both Router/Satellite to latest version V2.0.0.72. Looks like this have fixed the issues, Now on speedtest seeing speeds like 85-95mbps, Even near the Satellite which is like 35 feet away from my router also giving similar speeds.
So just wanted to ask one question. So I need to do a factory reset of both Router/Modem now after upgrading the firmware is this a must?
Thanks
