randomguywarwic
Aug 10, 2020Aspirant
Slow web browsing - pulling my hair out! RBK53 **Help**
Hi All - I installed the above Orbi router and 2 sataligts in my bungalow. They are in direct line of sight, R/S/S about 10m apart. Have the router connected to a Archer MR200 4g router (via network ...
randomguywarwic
Appologies - no.... My internet is sourced through a MR200 4g router.... This is connected to my Orbi, with the MR200 in bridge mode... With Orbi as my "home network and router" in this configuration, i have very slow weblage load time (but fast Streaming and online gaming). the only acception is one PC in the house, hard wired to the Orbi.
If i swith the Orbi off, and use the mr200 in "Router mode, with the wifi siwtched on - no speed issues ... (but ths coverage wont fill the house)
If i keep the MR200 in router mode and set Orbi to AP, problem still exisits... So Orbi is doing something somwhere, to dramatically slow down the web surfing.
randomguywarwic
Hi Furry - very good point - no it hasent.... The updates ran as out a fresh from the box install... Np fectory resent.... That may be a good "next point" to try..
- FURRYe38Aug 10, 2020Guru - Experienced User
:smileywink:
I would power OFF the ISP modem for 30 seconds and back ON during the the reset as well.
