osucoop
Sep 03, 2019Follower
Slow Wireless speeds for Apple devices (RBR50 / RBS50)
I just installed a orbi RBR50 with two of the RBS50 Satellites. I have installed the latest version of the firmware for both the router and the Satellites. The system is up and working well with re...
Sep 04, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
heathweather
Sep 04, 2019Guide
In addition to all of the excellent suggestions FURRYe38 has made, as a sidenote, I've had intermittant results with apple idevices. I've had an iphone XS and an iphone 8 side by side, run a speedtest, one at a time, using the same server on speedtest, the XS sometimes seems to be stuck on b/g/n, it caps out at 80mbps, while the iphone 8 consistently performs much higher - ~300mbps , I've got 1GB service. Both devices are iOS 12.4 , so I am unsure as to why the XS is somewhat hit and miss, while the 8 is rather consistent.
