JohnZxm
Jun 29, 2019Aspirant
SONOS One can't works in RBR20 with Wireless (only one RBR20,No satellite)
I have two sonos one device, It works connect to R6200 with wireless in before. As R6200 using so long time, So I buy new one ORBI RBR20 router replace r6200. After that time, My sonos can't work pro...
Will_T
Jun 29, 2019Apprentice
I am sure one of the experts here will come along tomorrow with some suggestions for your wireless issues with your Sonos. My Sonos is hardwired but just for your information it is working perfectly so far connected with about 15' of CAT6. It failed the first time I tried connecting it, but the 2nd time it worked. I did not have to do anything special for it. I just just pushed the button on the Sonos and then let the Sonos App go through the connection steps it does automatically and it was good.
- JohnZxmJun 29, 2019AspirantThanks for your reply,Wired the SONOS to RBR20 is works,But I need via wireless connect,RBR20 just one eth port,I need connect to my NAS
