pbarham
May 09, 2020Apprentice
Spanning Tree problem with Orbi RBR50
I have been having network problems with my Orbi system for a few months now.. The symptoms are similar to issues others have reported, where satellites and other devices gradually disappear from th...
Sep 25, 2020Guru - Experienced User
What is the mfr and model # of this switch your using?
Send feed back to forum moderators if you don't have access to official support channels here:
https://www.netgear.com/support/#
mdsteele47 wrote:I'm already using a non-managed, non-green switch as a part of the setup. The problem persists with that switch.
Dumb question... is there a way to send this feedback to NG? My 90-day support window with them is long past up and I can't seem to identify a way to just send them this information otherwise.
mdsteele47
Sep 25, 2020Aspirant
Current switch is a Tenga TEG1008D. I originally had the TPLink TL-SG108 with the same results.
- FURRYe38Sep 25, 2020Guru - Experienced User
And if you remove these switches and direct connect the RBS, do you see any continued problems?
- mdsteele47Sep 25, 2020Aspirant
Yes. (You and I have discussed this in this thread.)
I remember now. This was seen when you used that offending device with Orbi huh... :smileyfrustrated:
