subarctic's avatar
Jan 03, 2020
The Curse of the Changing Names
I've recently been re=victimized by the dreaded "Curse of the Changing Names"--i.e., when I go through the effort to change the name of a device connected to the Orbi network, it typically rapidly cha...
  • SW_'s avatar
    SW_
    Jan 03, 2020
    subarctic wrote:
    I'm on 2.5.0.38.
    Device rename was broken on v2.5.0.38, which was pulled from NG support website.  Manually upgrade Orbi/Satellite to the latest firmware version 2.5.1.8, which contains the fixes for device rename issue.
