BrianJ44
May 30, 2022Guide
Trying to use RBR 50 instead of Verizon Router -Orbi RBR50 with 3 satellites
I currently have my Orbi setup in A/P mode and am using with my Verizon FIOS gateway router. I also have a subscription with Netgear Armor for Bitdefender. The system works fine in A/P mode, but I lo...
May 31, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first.
https://kb.netgear.com/31100/How-do-I-set-up-my-Orbi-system-to-work-with-Fios
https://www.flyn.org/notes/g1100-bridge/
BrianJ44
May 31, 2022Guide
Thank you so much for your quick response. I will admit I do not totally understand everything you have said however, I agree Option 2 is where I am trying to get to. When you say "disable ALL Wi-Fi radios on the modem" do you mean on the Verizon Quantum Gateway? If so, I already completed that step when I set up my system initially following these instructions you refer to...https://kb.netgear.com/31100/How-do-I-set-up-my-Orbi-system-to-work-with-Fios.
Not sure how to do this step in your instructions..."configure the modems DMZ/Exposed Host or IP Pass-Through for the IP address the Orbi router gets from the modem". Is what you are referring to in this link...https://community.netgear.com/t5/Orbi/Trying-to-use-RBK50-instead-of-FIOS-router/m-p/1885585/highlig...?
I assume you mean...
Enjoy.
@Grethferth wrote:Problem was solved. I had to put the old Verizon router back online and release the IP from the Fios routes admin console. Once that happened the Orbi could see the Internet.
One other thing that happened was the DNS IP's needed to be changed (auto populated by Verizon), as they also interfeared with the connection to the Internet. I just went with 1.1.1.1 and 1.0.0.1, which worked fine.
Greth
Is the above what you are saying to do??? Do I get to the DSP's by going into the orbilogin.net and changing my Orbi DSP's there along with changing my Orbi from A/P mode back to router mode?
Thanks so much!!!
