vadordog
Feb 18, 2018Tutor
Unable to connect Wink Hub 2 to Orbi System
I have been unable to connect Wink Hub 2 to the Orbi RBK43 System, went through many failed attempts with Wink Customer Support and NetGear Customer Support. The Wink Hub 2 see's the Wi-Fi network wi...
Roamabout
Feb 18, 2018Luminary
Is there an actual leading space in the Obri wifi SSID ?. If there is perhaps the Wink device is sensitive to it (stripping it off) and is failing to connect.
vadordog
Feb 18, 2018Tutor
Roamabout,
Thanks! That was the solution, I added a space in fronto of the Wi-Fi Network name and it conneted right away!
Thanks again!
David
