jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
rhester72
May 09, 2017Virtuoso
Part of my confusion is the similarity of our setups - I'm on FiOS, front-ended by an EdgeRouter and using Orbi in AP mode, and I can't _make_ mine fail, even when I've deliberately tried. There has to be something else going on here. I agree there appear to be two camps, those who never have problems and those who often do, but assuming the hardware is indeed 100% identical, there's some other variable (outside of the firmware revision) we're all missing.
Rodney
fbraz50
May 09, 2017Apprentice
Different hardware internals is a possibility. These companies source their hardware from different vendors so the internals in your unit could be different from mine. It could also be a bad batch of units. I will check if there is a hardware revision version on my units. Also, I don't use FIOS. I'm on comcast and thought it was a comcast issue at first until I switched to the Asus AC68U and packet loss went away. Also, downgrading from 1.9 to 1.8 fixes my problem also.
