jmbarbs
Apr 28, 2017Apprentice
Update V1.9.1.12 Netgear officially announcing 'Improvement in wireless connection Stability'
Just downloaded the latest release V1.9.1.12 and noticed in the official release notes from Netgear it states as fix 'Continious Improvement in wireless connection stability'..Dosent spefically makre...
Flash008
May 11, 2017Luminary
I would not speak too soon.....
Updated to test code 60 minutes ago....
Sent Netgear my observations minutes ago.
fbraz50
May 11, 2017Apprentice
That doesn't sound good.
- Flash008May 13, 2017Luminary
48 hours and positive results. Required a second full factory reset after update, then everything started working well.
Will provide Netgear my officail detailed update on Sunday. Sorry, it will be private due to NDA.
- Bing-StrollerMay 13, 2017Luminary
I think the fact that you can indicate positive results is a very big step forward.
Looking forward to seeing the details when they can be made public.
Many thanks for the update.
- CafetomMay 15, 2017Star
Flash008, I too am testing the beta code.
After you upgraded, you say that you did a factory reset. Why did you factory reset? Did you see any difference after the upgrade but before the factory reset?
I have done the upgrade but not the reset yet. I have seen some different screens with different options, but no positive results. So I am debating on a factory reset (although I wouldn't know why this should be needed).
Tom
- Flash008May 15, 2017Luminary
Per instructions, a factory reset was requested. I am testing the code per Netgear's instructions. As with many software/firmware upgrades with many OEMs, there are times where a significant change in code, commands and kernel changes require a factory reset to insure old config commands that are no longer valid will not create undesirable impact. Hence the reset to insure no lingering old code, commands, etc are interfering with a new API, kernel, etc. I can say that the results were not positive after performing the first install, and factory reset. But I performed an additional factory reset and things have been much better, but not perfect. I sent my official response yesterday. Let's see what they do.
