leungwillwill
Jan 14, 2021Aspirant
Updated RBR50 to firmware 2.5.2.4 and then my Satellite showing disconnected
Dear all FYI. Before updates, my router and satellite are both working fine. I login my orbi app yesterday, and saw the "update" icon. And so I do the firmware updates as suggested. Now my main...
Jan 16, 2021Guru - Experienced User
Keep us posted....
leungwillwill wrote:As FURRYe38 suggested, I have send a PM to Blanca_O
Will look forward to the response. Thanks everyone!
leungwillwill
Jan 29, 2021Aspirant
It's been over a week or two. The updates is - NO REPLY from netgear!
I am so disappointed by their products and customer service. Will look for a new system that's not netgear now.
- vajimJan 29, 2021Master
leungwillwill wrote:It's been over a week or two. The updates is - NO REPLY from netgear!
sad based on what you've been through
is the orbi still under warranty? if so in the package there should have been a number to call
if not, have you performed a factory reset on all?
