pshoule
Jul 22, 2018Tutor
Using Router Configured as Access Point Cannot see Satellites in web browser application
I am new here but I did search the forum to try and find and answer to this question:
IThe routers and satellites are all running firmware 2.1.4.16. When the router is configured as an access ...
Jul 23, 2018Guru - Experienced User
What is the model of the NG switch?
Does the Routers web page see the satellites if you directly connect them to the router, by passing the switch?
pshoule
Jul 23, 2018Tutor
Thanks FURRYe38,
the switches are Netgear ProSafe JGS516PE. I must say I haven't tried that yet but I sure will tonight and let you know what happenned.
Thanks
Simon
