packetwerks
Apr 02, 2018Star
V2.1.3.4 Bridging
Starting a new thread specific to my issue. So I woke up this morning to V2.1.3.4 being installed. Not only was my wireless network down but so was my wired network. Started troublshooting and notice...
Apr 02, 2018Guru - Experienced User
You might try changing the configuration to daisy chain the 2nd Satellite off the first one, instead of both connected to the same switch and see if this changes anything. Don't enable Daisy Chain on the router. Just see if adding the 2nd Sat to the back of the 1st Sat does anything different. I would also just as a quick test, take the switch out of the mix and directly connect both to the Orbi router. See if anything seen is different.
I have this similar network configuration. There is 2 unmanaged switched between my 1 satellite and the router. I don't have a 2nd Sat at this time so I can't test this with you.
Is this your switches?
http://us.dlink.com/products/business-solutions/dgs-1100-16/
If so, these are managed switches...
packetwerks
Apr 02, 2018Star
I'll give that a try -- although this is one of those things where (this time!) I didn't change anything. There was a change within Orbi that made bridging different. I just am not sure what changed.
And yes, those are managed switches -- but like I said the configs are both factory default with no changes.
Thanks for the help!
