packetwerks
Apr 02, 2018Star
v2.1.3.4
My Orbi autoupgraded to v.2.1.3.4 this morning and I found tht ethernet backhaul no longer works. Is this expected behavior? Anyone else seeing this?
Apr 02, 2018Guru - Experienced User
OK, swap satellites around to see if the problem tracks or not..
packetwerks
Apr 02, 2018Star
I'll give that a try.
Question: Does the LAN port on the back of the router and/or satellite matter for wired backhaul? Out of habit I always put the connection to my switch (what I want to be the backhaul) in the LAN port closest to the power plug.
