Zablalbaz
Apr 26, 2020Star
Very slow network speeds on 5GHz network on Orbi RBR50 after months of solid performance
Hey All, Hopefully someone can help me with this. I just started noticing some really slow network speeds on my 5GHz connected network devices a couple weeks ago. This is after several months of ...
- May 02, 2020
Thanks to all who pitched in. Your advice was helpful! I just took a backup of the working config in case I need it in the future. Setting this as resolved now!
Apr 27, 2020Guru - Experienced User
Zablalbaz
Apr 27, 2020Star
Router and Satellite are connected via a Gigabit Ethernet connection. I do not use the wireless backhaul. I haven't measured the distance with a tape measure, but the router is downstairs on one end of the house in the living room, and the satellite is upstairs on the other end in a bonus room. I'd say maybe 90-100 feet apart in a straight line?
