Zablalbaz
Apr 26, 2020Star
Very slow network speeds on 5GHz network on Orbi RBR50 after months of solid performance
Hey All, Hopefully someone can help me with this. I just started noticing some really slow network speeds on my 5GHz connected network devices a couple weeks ago. This is after several months of ...
- May 02, 2020
Thanks to all who pitched in. Your advice was helpful! I just took a backup of the working config in case I need it in the future. Setting this as resolved now!
Apr 27, 2020Guru - Experienced User
Ok just checking this.
What is the Mfr and model # of the switch in between the RBR and RBS if your using one?
Zablalbaz
Apr 27, 2020Star
I have only Netgear equipment in my house. :-) Here is a simplified topolgy:
The Internet signal comes into my house via an AT&T BGW210 modem.
That goes directly to the WAN port of the Orbi router.
Signal then goes from a LAN port on the RBR50 to two uplinked Netgear ProSafe GS108 Gigabit switches that distribute ethernet to the rest of the house.
Orbi Satellite is plugged into the Gigabit network with a GS108 switch between it and the RBR50
I have no problem with the wired, Ethernet speeds. That checks out everywhere in the house. Just the wifi from the router and the satellite.
- FURRYe38Apr 27, 2020Guru - Experienced User
Is the RBR in router or AP mode wth your modem. Thats a modem with built in router features.
Hopefully the reset will return the wifi back to spec.
- ZablalbazMay 01, 2020Star
RBR is in Router mode. I haven't had time to do the factory reset yet. Too many people at home using the network now. I'll have to schedule an "outage" to get it done this weekend.
One other data point though. I took my old TP-Link Archer C9 and hooked it up to a LAN port on the RBR. I set it up to distribute a test wifi network, and I was able to connect to the 5GHz network on it and get a 800Mbps Internet speed test with my laptop. So I think we can safely assume that the problem at this time is with the Netgear Orbis.
My plan at this time is to try the factory reset with the latest firmware that I installed last week. If that doesn't fix it, I'll try to find the v2.5.0.30 FW and downgrade. Hopefully Netgear has those old firmware versions archived somewhere.
- tomschmidtMay 01, 2020Virtuoso
Netgear pulled the v2.5.0.x firmware releases as they were extremely buggy. Please either use the current latest v2.5.1.16 release from https://www.netgear.com/support/product/RBK50.aspx#download or the previous stable v2.3.5.30. I have been running v2.5.1.16 for a month and it has been the most stable release for me yet.
