Zablalbaz
Apr 26, 2020Star
Very slow network speeds on 5GHz network on Orbi RBR50 after months of solid performance
Hey All, Hopefully someone can help me with this. I just started noticing some really slow network speeds on my 5GHz connected network devices a couple weeks ago. This is after several months of ...
- May 02, 2020
Thanks to all who pitched in. Your advice was helpful! I just took a backup of the working config in case I need it in the future. Setting this as resolved now!
tomschmidt
May 01, 2020Virtuoso
Netgear pulled the v2.5.0.x firmware releases as they were extremely buggy. Please either use the current latest v2.5.1.16 release from https://www.netgear.com/support/product/RBK50.aspx#download or the previous stable v2.3.5.30. I have been running v2.5.1.16 for a month and it has been the most stable release for me yet.
Zablalbaz
May 02, 2020Star
Thanks tomschmidt. Just curious, are you getting better then 24Mbps Internet test speeds while connected to the 5Ghz wifi with that firmware version? And did you perform a factory reset after flashing the firmware? I'm getting ready to do this on my end and will report the results back as soon as I am done. I am hoping that the reset will do the trick, and get me back the speeds I lost after flashing to 2.5.1.8.
