fieldmedik
Oct 14, 2020Aspirant
VPN
I am in a foreign country and have an Orbi RBK50 mesh. I want to connect dumb devices (i.e. a tv, amazon echo, etc). I would like to connect to a to my friend's VPN using openvpn. I tried to set up V...
fieldmedik
Feb 12, 2021Aspirant
Please explain more about Voxel. I do not have fireTV they are android or roku. I have openvpn on the devices that support it but the TV's (as far as I have been able to determine} do not. I also would like Alexa to use the client VPN.
mith_it
Feb 13, 2021Luminary
In my opinion routing only done devices is a lot of work. If you want since devices to be routed through a VPN tunnel and some devices go out through your regular ISP you might want to install a raspberry pi or something like that.
If you want to route ALL your traffic through the VPN tunnel then you should check out Voxel. See http://www.snbforums.com/forums/netgear-ac-wireless.53/, make sure you have the right stock firmware and then flash the latest Voxel firmware. Please remember how doing this at your own risk and you should be comfortable flashjng firmware and if needed restoring the stock firmware with TFTP.
