diodorus
Jan 10, 2018Guide
Wake on LAN / WAN
Hello! I'd ultimately like to be able to wake a (wired) PC from WAN. I can currently do that from the LAN, for example from an andrid phone using a Wake On Lan app. But I can't do that from the WA...
diodorus
Jan 10, 2018Guide
I have tried that already, but didn't work for me. I forgot to mention that my ORBI is in AP mode, and I am using the virginmedia superhub (a rebranded netgear modem/router) as main router. (By the way: can anyone confirm if that method works when using the ORBI as router?)
That's why I was considering the telnet option: is there a command I can run on the ORBI via telnet to wake the PC?
NXIXN
Jan 10, 2018Apprentice
If you are using the orbi in AP mode it will have nothing to do with your WAN access to make WoL work as your NAT is on the modem/router. Also the port forwarding rules is not applicable on the Orbi router since it is only acting as an AP. You should forward the udp ports in the modem/router.
- diodorusJan 10, 2018Guide
Yes of course I was forwarding the ports in the superhub modem/router, not the orbi, how could I have done otherwsie, if it's in AP model?
Thath's why I also asked "by the way: can anyone confirm if that method [i.e. port forwarding] works when using the ORBI as router [instead of AP mode]?")
I appreciate your efforts but if you want to help could you please focus on my inital question about telnet: is there a command I can run on the ORBI via telnet to wake the PC?
- au10ticJan 10, 2018Tutor
I do not believe there is a way to reboot (turn on a pc from an off state) via telnet, i dont think there is a command for that. You can type help to see the commands available on a telnet session.
As for trying this, thats one of the things i will be using the orbit for. I havent bought it yet, but i've tried it on a router i am using as a bridge/repeater running DD-WRT, and i was able to accomplished this by doing port forwarding on the main router to the bridge's IP on port 7. And because how WOL works, the packet will be sent to the machine you are trying to turn on by using its MAC Address. Perhaps you may want to try that and see if it works, of course assuming that the mobile app you are using is capable of sending packets via WAN.
Thanks, I get these commands:
. : [ [[ alias bg break cd chdir command continue echo eval exec
exit export false fg getopts hash help history jobs kill let
local printf pwd read readonly return set shift source test times
trap true type ulimit umask unalias unset waitIn the meantime, I've changed the ORBI from AP to Router mode (although this is not ideal in my case because I "loose" the LAN ports on ISP router, which would be helpful to have access to), and - also having instructed ORBI to forward port 9 to the PC I want to wake up - the WAL now also works from the mobile. However I think I read in some posts that this usually only works temporarily, and you loose that after 15-20 mins, I'll see how this goes. au10tic: is that what you meant, or were you suggesting something else (that I then have not understood)?
- NXIXNJan 10, 2018Apprentice
I am confident that using a router to an AP mode disables most of the features of the router and one of them is port forwarding and this is true in any brand of router I have owned. Port forwarding is what you do to allow communication to a device behind a NAT and setting up a router as an AP disables the NAT.
- diodorusJan 10, 2018GuideBut (again) that's not relevant for my original scenario!!
I wasn't forwarding anything in orbi at that point of course, I was forwarding using the ISP router. The forwarding rule was exactly the same as the one I now have on the orbi. So it was the ISP router (Netgear superhub) that was not allowing the wow, since doing exactly the same on the orbi (now as a router) works, at least for the moment.
