diodorus
Jan 10, 2018Guide
Wake on LAN / WAN
Hello! I'd ultimately like to be able to wake a (wired) PC from WAN. I can currently do that from the LAN, for example from an andrid phone using a Wake On Lan app. But I can't do that from the WA...
diodorus
Jan 10, 2018Guide
But (again) that's not relevant for my original scenario!!
I wasn't forwarding anything in orbi at that point of course, I was forwarding using the ISP router. The forwarding rule was exactly the same as the one I now have on the orbi. So it was the ISP router (Netgear superhub) that was not allowing the wow, since doing exactly the same on the orbi (now as a router) works, at least for the moment.
NXIXN
Jan 10, 2018Apprentice
I read your reply to au10tic that it is working now though your worrying it might be just temporary. Anyway, glad to hear it is working at the moment.Hopefully, it will stay solid with the Orbi.
