jeraboom
Oct 13, 2020Star
Web UI says RBW30 Update Failed, but there is no update available.
I have a system with an RBR50, 2 RBS50s, and 1 RBW30. When I use the router Web UI to check for firmware updates, it first attempts to download new firmware for the RBW30 and then says "Update Faile...
- Oct 20, 2020
RBW30 latest firmware v2.6.1.6 has been posted on the Support Site. Here's the link:
https://kb.netgear.com/000062471/RBW30-Firmware-Version-2-6-1-6
Blanca
Community Team
Oct 16, 2020Guru - Experienced User
V4 is the latest for the RBW. No need for any update. I presume the update services are incorrectly reporting this for the RBW. Should be No Update Available. Maybe a forum moderator and check on this.
Tgterm wrote:Exact same configuration and issue with the RBW30 Update Failed here. I was able to update my RBR50 and RBS50 by unplugging my RBW30, but has there been a resolution to the Update Failed issue on that satellite yet? Or, is Firmware 2.5.0.4 for the RBW30 the latest, therefore nothing to fix? Thanks!
Online UpdateManual Update
Firmware UpdateCheck if a new firmware version is available on the Internet.
Model Name Device Name Current Version Status Router RBR50 RBR50 V2.5.2.4 No new firmware version available. Satellite RBS50 RBS50 - Kitchen V2.5.2.4 No new firmware version available. Satellite RBS50 RBS50 - Upstairs V2.5.2.4 No new firmware version available. Satellite RBW30 RBW30 - Basement V2.5.0.4 Update failed
