ryanpc
Mar 21, 2019Guide
What is the latest firmware I should be running on my RBR50?
Current firmware 2.2.1.210 (says there are no updates)
From netgears page however it appears there is version 2.2.1.212 and 2.3.0.32 available
Any help is appreciated
Chuck_M
Mar 22, 2019Mentor
Since my previous comment above there has been yet another firmware release that updates the .32 version to 2.3.1.44.
The list of things it claims to resolve are pretty significant, so although you may THINK you are not having issues, your performance and reliability would increase by going to the newest.
You still have to manually get to .32 as is previously described and then have it update to .44
Some may say if it aint broke, dont fix it, but in this case I think it is very much worth the effort.
SeaMonkey80
Mar 22, 2019Apprentice
where are you seeing the .44 release, in the GUI or online? also, any chance you can list the changes vs .32? I do not see the .44 on the netgear firware update website for the RBK53. thanks
- tequilatramMar 22, 2019Tutor
Mine just updated to .44 last night as well. Here are the release notes from a different forum post:
Changelog:
- [Bug Fix] Fix issues with the Apple HomeKit connectivity
- [Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress
- [Bug Fix] Fixes the WiFi disconnection and IOT issue
- [Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic breween the main host and guest
- [Bug Fix] Fixes the Ethernet backhaul boot-sequence issue
- [Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256
- [Bug Fix] Fixes the JP/AU/CA region can't firmware update issue
- [Bug Fix] Fixes Armor activation failed due to device offline issue
- FURRYe38Mar 22, 2019Guru - Experienced User
v44 is thru the autoupdate feature on your routers web page. v32 files are online for download.
- Chuck_MMar 22, 2019Mentor
Thanks for posting the change logs.
The .44 version does not have manual update files (so far). It showed up in my Orbi Web Gui under advanced admin firmware.
Remember, you still have to update to the intermediate and .32 before getting this.... I know it is a pain, but you didnt have anything to do on a friday night did you!? LOL
