KMWNAZ
Apr 17, 2018Tutor
Which devices do I buy Outddor Satellite
I am looking to install an RBS50Y Outdoor Satellite. I am pretty sure I read that I can only connect it to an Orbi Router. Which one do I buy? So far all I seem to find are Kits including th...
- Apr 17, 2018
Hopefully this helps:
Yes, the Outdoor Orbi (RBS50Y) is only sold as a stand-alone, meaning that you have to purchase an Orbi Router from elsewhere. A couple of suggestions:
1. purchase a kit that contains an Orbi Router (e.g. RBK50 / RBK30 /...) and sell off the extra satellite on a 2nd hand site (e.g. eBay, ...)
2. purchase the Router online in a 2nd hand site. I occasionally see people who have purchased 2 kits, to acqure just the satellites and the Router becomes extra.
FYI, from a purely performance perspective, the RBR50 is the best matched because it's the only Orbi Router that has a 4x4 backhaul.
I will take this back and see if we can create a kit for those like you.
Orbi Product Management
Retired_Member
Apr 17, 2018
KMWNAZ wrote:Not really. I ONLY want to extend to the outside. All of the ORBI systems I see seem to include and INDOOR satellite. and a router I would only require the router.
OK....but I'll stay confused. You said..."I am looking to install an RBS50Y Outdoor Satellite"....but then you said ..."I would only require the router"
KMWNAZ
Apr 17, 2018Tutor
I don't mean to be misleading. If you look on Netgear's web site it appears to me that they ONLY sell ORBI routers WITH an INDOOR satellite. I only want an OUTDOOR satellite and I believe in order to use the OUTDOOR satellite it requires an ORBI ROUTER.
So going back to my first sentence - Netgear appears to only sell routers with INDOOR satellites which I don't need. So I am trying to confirm all of this.
Make sense?
