KMWNAZ
Apr 17, 2018Tutor
Which devices do I buy Outddor Satellite
I am looking to install an RBS50Y Outdoor Satellite. I am pretty sure I read that I can only connect it to an Orbi Router. Which one do I buy? So far all I seem to find are Kits including th...
- Apr 17, 2018
Hopefully this helps:
Yes, the Outdoor Orbi (RBS50Y) is only sold as a stand-alone, meaning that you have to purchase an Orbi Router from elsewhere. A couple of suggestions:
1. purchase a kit that contains an Orbi Router (e.g. RBK50 / RBK30 /...) and sell off the extra satellite on a 2nd hand site (e.g. eBay, ...)
2. purchase the Router online in a 2nd hand site. I occasionally see people who have purchased 2 kits, to acqure just the satellites and the Router becomes extra.
FYI, from a purely performance perspective, the RBR50 is the best matched because it's the only Orbi Router that has a 4x4 backhaul.
I will take this back and see if we can create a kit for those like you.
Orbi Product Management
CrimpOn
Apr 17, 2018Guru - Experienced User
You are correct. Netgear's ORBI system of products consists of a central host device (set up either as a "router" or as an "access point") and one or more satellites. (Yes, a person can install only the central device, but that sort of defeats the whole purpose of ORBI.) All of the ORBI satellites, including the outside model, only function when they connect to the host device.
What you appear to want is a weatherproof WiFi access point (to mount outside) that connects wirelessly to your modem or router inside the house and NOT to an ORBI host inside the house. Those products exist. Of course, they have different characteristics than an ORBI system (separate SSID's, no seamless handoff, etc.)
Sorry if I have misunderstood.
KMWNAZ
Apr 17, 2018Tutor
Well, actually what I would want in an ideal world is an ORBI system that consists of the OUTDOOR satellite and an ORBI router. It appears they do not sell that system though.
I am not trying to connect the OUTDOOR to a non-ORBI router. I just don't need the additional INDOOR satellite that accompanies the systems I see online.
- Retired_MemberApr 17, 2018
KMWNAZ wrote:Well, actually what I would want in an ideal world is an ORBI system that consists of the OUTDOOR satellite and an ORBI router. It appears they do not sell that system though.
but I have to ask....what is it that you're trying to connect outdoors?
- FURRYe38Apr 17, 2018Guru - Experienced User
This would not work for you?
https://www.netgear.com/orbi/rbs50y.aspx
FURRYe38 wrote:This would not work for you?
what?....so i took the OP's recommendation and went to the NG website. The RBS50y is a 'ADD-ON' and a Orbi router is required as in the Orbi is considered a SYSTEM and the router can not be purchased separately.. Nice
- AmitRApr 17, 2018NETGEAR Employee Retired
