dubirl
Feb 25, 2017Tutor
Wifi keeps dropping
Replacing my 2 Airport Extreme APs & 1 Airport Express (one on each floor) The GND floor Airport Extreme was connected a SKY router. I relaced all the Airport fit with the Orbi router RBR50 and Sat R...
DarrenM
Sep 06, 2017Sr. NETGEAR Moderator
Send me a PM with your name, email, and phone number and a quick summary of your issues and I will get you in contact with support to figure out the issues with the disconnects.
DarrenM
alberts
Sep 07, 2017Star
Hi darren,
have a look into case (#28835167). i'am not wasting more time describing my problem. i have firmware 2.0.0.64 in the meantime, still have ongoing disconnections. I'am done with that crap by now, left approriate review at amazon.
in a few weeks i well check for new firmware. maybe it will work then it's fine, otherwise i dump netgear for good and dont waste any more time. good luck, netgear has for sure lost a customer and i will leave negative reviews till you come up with a firmware that works. albertS
