aldao
Oct 21, 2017Aspirant
Will Orbi work with Nighthawk Smart WiFi Router
Hi, I recently purchased Orbi router with Satellit to cover to my 3000 sf house. I'm currently using 9000 NightHawk WiFi router. I connected the Orbi router via Eithernet cable from the 9000 Nigh...
- Oct 21, 2017It did help! Thank you for your help.
peteytesting
Oct 21, 2017Hero
hi
your best setup is to run the r9000 as your router and disable its wifi and use the orbi behind it in access point mode , the r9000 has a better cpu and ram so as a router will work better and leave the wifi to the orbi in ap mode
