tjochem
Aug 21, 2020Aspirant
Wired Backhaul Problems with RBR50/RBS50
Hi, I'm at wits end. To support some virtual schooling, I reconfigured our orbi setup. RBR50 is in AP mode. 2 Satellites. Because the one satellite is in an addition, behind a brick wall, I wanted t...
- Aug 21, 2020
If CAT5, or possible bad cable could cause some problems if not working well.
What is the Mfr and model # of this switch?
Try this, turn OFF the one wireless RBS and leave the wired RBS connected. Does the problem still happen?
tjochem
OK. I will get this info and post back.
tjochem
The switch is a cheapo TP-link TL-1008D
I am testing the cable problem theory. There is another port in the room the wired connection should be in. Testing with that port now. It comes up and the backhaul config is correct for both satellites. (Wired and 5G)
- FURRYe38Aug 22, 2020Guru - Experienced User
Is there a SF or SG in the model name of that switch? I see if its SF then speeds are rated at 100Mpbs while SG is rated for 1000Mbps.
Sounds like sonething between this room and the RBR is bad with last port used.
- tjochemAug 22, 2020Aspirant
Yes, the complete Model # is SG1008D - its a Gigabit switch.
Update - everything worked through the night without incident.
So, contrary to by initial hypothesis, it seems like it was the port I was using in the room.
As usual, it was the most obvious, non-technical thing. Couldn't see that.
THANK YOU!
Ok thank you for the details.
Glad you found the real problem.
Enjoy now. :smileywink:
