Geek95
Aug 22, 2016Follower
Wired Connection to Satellite
Is it possible to use Ethernet to connect router and satellites?
mdgm-ntgr
Aug 22, 2016NETGEAR Employee Retired
No, but this is a suggestion under consideration.
Part of the beauty of the Orbi solution is how it effectively connects the router to the satellites wirelessly. There is very good penetration.
Dima1007
Sep 30, 2016Aspirant
Is it possible to add and use Orbi router in AP mode as second satellite?
- peteytestingSep 30, 2016Hero
sure
if you mean set it to ap mode and it run as an ap and the sat then run as a further ap
