esiebert7625
Oct 04, 2018Star
Your experience with Firmware 2.2.1.210 released as of 10/3/18
The other long thread on the new firmware is useless and has become a tech support thread. Please only post your experience after upgrading to the new firmware, good or bad. I'd like to see everyone'...
netadmn
Oct 06, 2018Apprentice
TLDR: Updated without issue. Devices showing slightly decreased signal strengh but the wireless network has been up/down so it'll probably sort itself out after roaming a bit.
I manually updated tonight to work out any issues before next week and risk any unplanned outage from Orbi updating itself. I've had that happen in the past and I'm still mad about it. I wasn't looking for any specific features or fixes from this firmware. It's hard to get excited about release notes that say esentially "fixed some stuff" without going into detail about what was fixed. I'm used to release notes being dozens of pages long that details specifics... Netgear has major updates with 4 line release notes. haha!
Disclaimer: I have a nonstandard deployment in AP mode doing all the things that gives FURRYe38 nightmares...
Setup: I have the RBK53 in AP mode connected through a managed switch (yes... with IGMP snooping enabled!). My gateway is a pfsense sg3100 with the RBR50 as the Orbi "router" and two sats RBS50. L3 services such as gateway/routing, DHCP, DNS, mDNS/IGMP, etc. are all handled by my sg3100 firewall. Orbi has BEAMFORMING, MU-MIMO, and Fast Roaming enabled. 2.4GHz and 5GHz SSIDs split with different names. Daisy Chain is disabled. I'm wireless backhaul with pretty close proximity (4000 sq ft 3 floor home) with maybe 40 feet betwen the sats and the router. I have the router and one sat on either end of the middle floor. I have another sat in the middle of the top floor.
Update Experience: I've read to update sats before the router so I started to do that. I updated one RBS50 and it rebooted twice. No issue. Uploaded firmware to the other RBS50 but it timed out before I could complete the firmware upload (so I thought). Turns out the RBR50 (which I didn't upload firmware to) had decided to update itself. When the 3 devices came back up, they all reported updated firmware. 5G backhaul to the BRK50 like before. I did NOT perform a factory reset and have not for the past several firmware updates.
Before/After Testing: I have a Verizon FIOS 150/150Mbps connection. Download speeds before and after remained mostly the same 151/149 has been the average from my Samsung S9 over the last hour and a "quiet network" (everyone else is in bed) and I'm just listening to music. I ran some tests on DSL Reports before and I was getting A+ or A ratings for Overall, Bufferbloat and Quality. (I'm using pfsense + CoDel to manage my up/down bandwidth.) Bufferbloat rating went down a bit but tweaking the queue has helped a little bit. mDNS browser shows all my Google Home/minis, chromecasts, echos, wemo plugs, etc. are all back up. At first glance the majority of our devices are online... I normally see 40+ active devices during the day and tonight I only see 30 which is about normal for night.
Conclusion: If this stays the same... that will be 2 firmware updates without issue. Time will tell as to the stablilty but initial impressions are looking good. Family will put stability/streaming to the test with their devices over the weekend.
AC641
Oct 06, 2018Luminary
I updated my RBR50 and RBS50 manually on 03 Oct. I had no issues with the previous firmware except that I used to see occasional momentary loss of WiFi on my iPad when it was conected to the satellite. So far I have not seen this with the updated firmware but I think it's too early to say that it has definitely been eradicated.
- AllanSorOct 06, 2018Tutor
2.2.1.210 made my sat useless.
Beta 2.2.1.204 has been stable for a week, no drops in wifi from router of sat, wireless backhaul.
Autoupdated from beta 2.2.1.204 to 2.2.1.210 via web gui, sat would not connect again. HW reset sat and removed sat from router web gui. Added sat again. All looked fine, no packet loss and backhaus status "good"
Lost wifi on sat 3 to 4 times pr. hour, router is still fine. Backhaul status is "poor" all the time, moving sat closer to router made no difference, backhaul will not connect via 5 Ghz and status is "poor"
Manual updated fw to 2.2.1.210 first on sat and the router. Factory reset and started over, all worked for 2 hours, backhaul 5 Ghz "good"
now sat loses connection to router 3 to 4 times pr. hour again. Wired backhaul is not an option for me and 2.2.1.204 was fine (the best to date)
Wifi on router is fine and has no drops but 2.2.1.210 made my sat useless.
- steve8411Oct 06, 2018Apprentice
Knock on wood. This one has worked flawlessly for the past 2 days.
No factory reset...
It was a bit wonky after install waiting for sats to come back online ...
But, so far it appears my problems have subsided.
- AC641Oct 08, 2018Luminary
There it is! The issue I have been experiencing with my iPad momentarily disconnecting from WiFi when supposedly connected to the satellite has just occurred. v2.2.1.210 still has this issue present for me. I can't tell and haven't investigated whether it happens with other devices as I don't routinely have other WiFi devices connected to the Satellite except security cameras and my iPhone and I'm not using these for extended periods unlike the iPad.
- FURRYe38Oct 08, 2018Guru - Experienced User
Is your satellites wired or wireless connected? Some of mentioned that enabling Daisy Chain in this new version has opposite effects. Enable seems to be Disable and vs versa...Something to try out and see.
- AC641Oct 31, 2018Luminary
For the past week or so I have been experiencing loss of internet connectivity - approximately once a day. This is definitely an issue with the Orbi Router and not the modem as I have proved that the modem is still connected and accessible when internet connectivity is lost. I have changed Ethernet cable but no change. A reboot of the Router or modem rectifies the issue.
- ekhalilOct 31, 2018Master
AC641, This can very much be caused by wired devices.
This software seems to have issues with some wired devices. If you have any mesh speakers (e.g. Sonos) wired to Orbi, please test to disconnect them and see if you will see improvements.
Wired Sonos seem to -in certain conditions- cause IP loops over time which will degrade the system performance and will consequently cause different "strange" issues.
