rickgans
Jun 05, 2018Tutor
Reaching Tech Support
How does a customer reach Orbi tech support? I called today and after a one hour hold, the call was answered by a rep who told me she would transfer me to the Orbi department. I was then put on hol...
st_shaw
Jun 05, 2018Master
Sonos should work fine with Orbi. However, they both use the same 2.4 GHz WiFi spectrum, so you will have problems if Sonos and Orbi are not configured properly to work together.
You need to either:
1) Wire one, and only one, Sonos device to your network. Manually set Sonos to use channel 1. Manually set Orbi to use channel 11 on 2.4 GHz. (Or vice versa.)
OR
2) Wire none of your sonos devices and connect them all via WiFI.
I use approach 1) and Sonos and Orbi work together with no issues. In this configuration Sonos creates its own wireless mesh network (Sonosnet) that is independent of Orbi.
Wiring more than one Sonos can cause network loops. Using managed switches with Sonos can also cause ports to be blocked by the spanning tree protocol.
You also need to be careful not to place a Sonos unit right next to an Orbi, or that can cause problems too.
rickgans
Jun 05, 2018Tutor
Sonos worked perfectly with Orbi...until it didn't. I think the problem is with the fact that Orbi started dropping its wifi signal sporadically about 3 weeks ago. That totally coincides with when Sonos went from working perfectly to when it started working poorly. As part of the troubleshooting, I disconnected the Sonos Boost (the only Sonos device I have wired to my network) for a few days. The Orbi system continued to have problems keeping wifi going. I did not try using Sonos during that period, as I figured it was not connected at all and would not work at all.
I read many web postings about Orbi dropping wifi and there being no fix for that. But I have a hard time believing that is the case. That is why I reached out to Orbi tech support and was even willing to pay for support. But I had to give up after waiting on hold for 5 hours and that is my beef. I am going to try again when I get home in a little while and see if I can reach Orbi tech support.
- st_shawJun 05, 2018Master
If you had a Sonos Boost plugged into your LAN, then Sonos was not using your WiFi at all--Sonos was using Sonosnet. Orbi's WiFi could fail completely and it would have had zero effect on Sonos. (The only exception would be if the Boost was wired to a satellite, and then Sonos would be using the Orbi backhaul, indirectly.)
Unless you already took the steps I described and manually set non-overlapping channels on both Orbi and Sonos, then Orbi and Sonos could conflict with each other at any time, if either one automatically changed channels to overlap with the other.
I don't know whether this was the cause of your issue, but it is a configuration step that is necessary to avoid problems.
Good luck.
- rickgansJun 05, 2018Tutor
Thank you for your help with the Sonos issue. That is actually not the problem that I am trying to solve. There are two problems that are bigger than the Sonos problem. One is reaching tech support for Orbi. I described my problem earlier today with waiting on hold for 1 hour only to be told I had to be transferred and then waiting another4 hours and no one ever coming on the phone to help me. I am on the phone again with them right now and the person I am talking through is putting me through what is now a 20 minute interrogation about my email address, case number and the fact I have to be transferred . I am able to wait for up to another 4 hours as I am home for the night. But why does it take 4 hours to talk to someone at Netgear?
Problem two is that the wifi goes out randomly for no known reason. It is out as I type this. No connection from my phone, wife's phone, Ipad, Amazon Echos, Ring Doorbells, Nest Cams. No wifi signal. I mentioned Sonos earlier as a casulty of this, but that was not the main problem.
Has anyone had good tech support from Netgear? I am going to have to get this solved or sell this poor equipment and go back to using an Eero, which I will have to buy all over again.
- DarrenMJun 07, 2018Sr. NETGEAR Moderator
Hello Rick
If you are still having issues reaching support please PM me I will be able to help.
DarrenM
