carlsson
Mar 30, 2021Star
Really strange connectivity problem
My Orbi RK50 network (one router, two satellites) have worked flawlessly since I bought it last summer. Suddenly, two days ago, the network started to not work in a really strange way: - It appeared...
- Mar 30, 2021
There is a horrible situation that started with the change in Daylight Saving Time that causes certain Orbi RBR50 routers to stop resolving Domain Names until they are restarted. Netgear engineers have traced the problem to a coding error in the Traffic Meter feature. Looks like there is abolutely no chance Netgear will release a firmware fix before April, so the easiest solution is to go into the Orbi web interface, Advanced Tab, Advanced Setup, Traffic Meter (toward the bottom of the menu) and uncheck "Enable Traffic Meter" and Apply.
CrimpOn
Mar 30, 2021Guru - Experienced User
carlsson
Apr 01, 2021Star
Thanks, that seems to have solved it! đ
Furthermore, my WiFi speed is back.
Definitely one of the strangest network related errors I have seen in my 30 year as an IT consultant.... đ
