byteman
Mar 27, 2020Aspirant
Reboot Option
Have been trying to use the ip reservation option. I read elsewhere that you must reboot the orbi router after adding a new reservation. So I look around for a reboot option (seemingly a stand...
- Mar 27, 2020
After setting up the IP reservation and adding it, you need to select the apply button. When you do this, the RBR will itself reboot. AT least the server reboots. You can also force the reboot on the RBRs web page under Advanced Home Tab page.
Mar 27, 2020Guru - Experienced User
- bytemanMar 27, 2020Aspirant
Thanks - Didn't see the reboot option - it was right in front of my face on the page you mention - but oddly couldn't find it in the manual. And I can confirm that the reservation "Apply" button is not the solution - doesn't make any difference if the "reserved" hardware is powered up, powered down, rebooted, or whatever.
- FURRYe38Mar 27, 2020Guru - Experienced User
Also you have to reboot your connected devices as well after you make the change on the RBR.
Enjoy. :smileywink:
