Bobne's avatar
Bobne
Receiving Wi-Fi Signal in a metal outbuilding
I have an Orbi RBR50 in the east side of my basement. In the west side of the upper level of the house I have the Orbi extender. About 20 feet away from the extender I have a metal outbuilding. I cannot receive any Wi-Fi  signal in the building. Any ideas?
  • FURRYe38's avatar
    Metal will prevent wifi signal travel. Run a buried or over head ethernet CAT6A cable from the house to the metal building and put in a RBS or EX model extender connected to the ethernet cable.
  • CrimpOn's avatar
    CrimpOn
    FURRYe38is correct.  Installing an ethernet cable between the house and outbuilding is guaranteed to work.  Alas, even 20 ft. can sometimes present a problem.  (Lots of concrete. Association restrictions on aerial wiring.  Building penetrations.  etc.)
    Another solution would be a window facing the house.  i.e. Cut out the metal between two studs. Frame it with 2x4's.  Screw on a piece of plexiglass. Caulk around the outside.  Doesn't have to open, slide, or anything.  Just be "not metal".  Place a WiFi repeater (on a shelf) in the opening.  An RBS40V Orbi satellite is selling for $99 on Amazon.  I have used Netgear EX3700 WiFi extenders at half the cost.
    So, which costs less and is easier to do: (a) install a cable, or (b) put in a window?
    • Bobne's avatar
      Bobne
      Thanks for the help! I think running an Ethernet cable would be the best bet for my situation. Just want to verify I can run the cable from the extender from the house to an EX3700 in the outbuilding.
      • CrimpOn's avatar
        CrimpOn
        Using ethernet requires both ends to support ethernet.  All of the Orbi satellites have a LAN jack except the wall plug model.
        The EX3700 expects to "extend" using WiFi, so it would have to be some other WiFi access point that connects to ethernet.
        The RBS40V has been selling on Amazon for $99. (They will do almost anything to hook people on Alexa.  I just left that feature disabled.  Who knows, you may enjoy having music in the building.)
        If you are willing to give up the Orbi "mesh" feature, there are many WiFi access points that cost even less.
        Be sure and get "outdoor rated" ethernet cable.
