estebinbin
Mar 31, 2021Aspirant
Recent disconnects with my Orbi RBR50, have to unplug power to get running
Hello everyone, first time posting here. I am sure this has been mentioned in the past but I did not see any recent posts on the subject. I have a Orbi RBR50 system, router and one satellite. All con...
vajim
Mar 31, 2021Master
do search...1000's post on your firmware
uncheck the traffic meter
you may have to fiddle with the DST settings as well
OR....................you can revert your firmware
estebinbin
Thank you for the suggestions, I will look around more to see what people have posted on the current firmware. I just turned off traffic meter, I do not see how to control DST off the app but I will look around some more. I hope I will not have to go throught the trouble of having to revert the system.
- vajimMar 31, 2021Master
estebinbin wrote:Thank you for the suggestions, I will look around more to see what people have posted on the current firmware. I just turned off traffic meter, I do not see how to control DST off the app but I will look around some more. I hope I will not have to go throught the trouble of having to revert the system.
you'd be better off not using the app and make your adjustments logging in using a pc
you may want to check with Ha_Ku_Na for he had a great post offerring solutions to this problem
