seagreen
Jun 04, 2018Aspirant
Recently purchased RBK23 and am having a LOT of problems
Model: RBK23 (wasn't accepted above)
The firmware is up-to-date One satellite is fine but one is not.
For backhaul it says: config sync
The light is amber
For connection it says 2.4 GH...
SDplinker
Jul 16, 2018Guide
RBK23 - new owner - 3 days.
After a lot of issues due to my old router conflicting with the Orbi, the wireless backhaul seems solid. Tried plugging in one of the satellites to my LAN - the whole thing dropped. Any ideas? Wait out the firmware? I'm on the latest 2.1.4.16
- FURRYe38Jul 17, 2018Guru - Experienced User
How is the system connected between the router and satellites?
Any networks switches in between the router and satellites? If so, Mfr and model# of the switch.
Besure your using good quality LAN cables. CAT6 recommended.
I would disconnect ALL other LAN networking and devices before trying to connect the satellites via wired backhaul. Once you have the wired back haul setup and running, then connect the rest of the LAN networking devices.
